Thread: 1st Build, Second machine
26-08-2011 #21
Hi Micheal,
Dont do it.!. . They dont even compare in the slightest. Even with the best alignment and boring, reaming etc they still dont hold candle to linear bearings and will wear far quicker, far too much hassle IMO.
If you do go with linear rail drop me a PM before you buy I probably can help.?
29-08-2011 #22
Okay with the advice given and working in ViaCAD to get things set up would like folks opinion of the following set up for a Y Z axis set up.
The dimension marks are left over from getting the height right from the table surface and still having space for the 4th axis.
So please folks opinions. This is not complete. The Y is a little to long (was learning how to download files from Hiwin, great set up they have) and the screws on the Z and the Y are yet set in, nor is the anti back lash nut for Y (it will be between the two rails).
There are 4 carriages holding the Z axis to the Y even though you only see 2.
opinions please.
MichaelLast edited by m.marino; 29-08-2011 at 10:57 PM. Reason: Add addtional information.
29-08-2011 #23
Put the rails on the front plate and the bearings on the back plate. This way the rails help stiffen the front plate.
The carriages then go low on the backplate and it makes for a very stiff z axis with max support where it's needed.! close as possible to the cutting end.!
Edit: Also if you pocket the bearings into the back plate slightly you regain some of the lost stand off from gantry. Also you can use one of the pocket edges as a datum ref point for alignment of the bearings. If you also do the same with the rails into the rear of the front plate, (but not quit as deep) this as the same affect and also another datum ref edge.
The net affect of both brings the stand off from the Y axis down slightly and also creates accurate ref edges to work from which are essential for setting up profiled linear rails correctly.
Hope this makes sense.! If not just ask and i'll try to explain better.Last edited by JAZZCNC; 29-08-2011 at 11:37 PM.
30-08-2011 #24
If the rails are contributing significantly to the stiffness of the material you are using for the Z-axis then that material should be made thicker/stronger. Still definitely put the rails on the front plate, but primarily for the second reason - the supporting carriages are closer to the bed.
30-08-2011 #25
Not sure why you felt the need to post that.? . . . My point was the rails on front plate is much stronger way and no where did I suggest useing it prop up a flimsy front plate.!! . . . Thou if we are splitting hairs then a correct design should factor in all materials plate rails etc to give optimum strength without over engineering which wastes money and effiecency.
Bottom line rails on front is stronger.!!
30-08-2011 #26
Okay will do rework with those ideas in place and try to add the rest of the pieces in place as well so that it makes sense. I have to say that i really like working with ViaCAD 2D/3Dv8 (yes I am an unpaid broken record but it is soooo easy to get things right where you want them and surfacing is extremely easy. Will make the changes and see what other gems and insight you will be willing to teach me.
Michael
30-08-2011 #27
This, in my opinion, suggests that:
Either way obviously I agree that rails on the 'front' is strongest. It's one of a number of things virtually everyone does wrong to start with, myself included. It also reduces the length of material required for the Z-axis. The only disadvantage I can think of is that you're also having to move the stepper motor and screw against gravity ... but that's almost certainly negligible.
Ideally you should also machine a slot in the plate for the rails so that one of them can be clamped in place. The same is true for the bearing blocks. If the machine crashes it helps stop them move out of alignment. I don't know if you have a milling machine though?
Perhaps there wasn't much point. I thought I was reinforcing/clarifying it.Last edited by Jonathan; 30-08-2011 at 07:22 PM.
30-08-2011 #28
Ok obviously miss understanding but either way flimsy or strong it's fact the rails would help support.!
First let me say dont be fooled by the lack of post's, I've been building diy cnc machines both for my self and others for meny years so I know very well all the newbie mistakes and pitfalls I just havent posted on here.
Regards the down side and your thinking you have to move the steppers with the front plate. It makes no differnce rails on rear or front both you can still have the motor static with the right design. Your right thou the difference is negliable.
I have 2 machines a large and small the large machine use's the moving screw,stepper arrangement with nema34 stepper and the smaller machine use's the static stepper,screw with nema23 stepper both work equally well. The only difference or advantage to the moving stepper arrangment is that it use's slightly less material because you dont need the high backplate but again the saving is negliable.
Eh eh now here's my chance to point out or clarify something you said.!!! . . . When using Profiled linear rails it's important you have a datum referance edge but not for helping stopping them move when crashed, the main importantance is for the alignment when installing. The point being that you fasten one rail tightly up against the referance edge using the correct edge of the bearing or rail depending in which orientation you have them ( they do have a right and wrong way).
Then you tighten the opposing or what I call floating rail or bearing losely then slowly move the gantry or table along the rail nipping the bearing or rail as you go along feeling for any tight spots and losening adjusting the floating rail or bearing to eliminate tight spots. . . . Simplezzs.!
30-08-2011 #29
Why do my posts keep getting sent to the moderator for approval.???? . . . There's nothing wrong in any of them. . . Arghh My pet hate is sensorship.!
30-08-2011 #30
There are currently 13 users browsing this thread. (0 members and 13 guests)
CNC Build - TEP milling machine conversion
By craynerd in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 06-07-2015, 02:09 AM -
Someone to help me build a machine
By mandev in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 29-01-2014, 02:07 PM -
DIY Machine to Build?
By paulkane1 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 03-12-2012, 02:24 PM -
NEW MEMBER: Second machine build
By tmsboss in forum New Member IntroductionsReplies: 1Last Post: 04-09-2010, 01:11 PM -
Best Type of Machine to Build?
By Kevin in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 05-08-2009, 02:50 PM
