Thread: 1st Build, Second machine
If I've worked it out right, all that's needed is a bit angle, with four holes on one side for bolting to the cross brace, then on the other side a big hole (21.5mm) for the anti-backlash nut to pass through, with another two holes for bolting the nut on via the flange (having looked at the dumpsterCNC site, I'm guessing you're for the 25mm cut-down flange option?).
Something suitable could be made with a pillar drill, a couple drill bits, and a hole saw.
Regarding mounting the nut, I'd use a couple nyloc nuts with plain washers to spread the load. I'd also put the bolts through from the alloy side, tighten them into the flange, then use the nylocs to make sure the bolts can't move.
19-08-2011 #2
CNC Build - TEP milling machine conversion
By craynerd in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 06-07-2015, 02:09 AM -
Someone to help me build a machine
By mandev in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 29-01-2014, 02:07 PM -
DIY Machine to Build?
By paulkane1 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 03-12-2012, 02:24 PM -
NEW MEMBER: Second machine build
By tmsboss in forum New Member IntroductionsReplies: 1Last Post: 04-09-2010, 01:11 PM -
Best Type of Machine to Build?
By Kevin in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 05-08-2009, 02:50 PM
