  1. Okay,
    Now you really got me thinking of ways to not only improve what I have but make the new one even better. Also with the two carriage stacked like that on the Z I would assume that you need to increase the length of plate to allow the travel I want to attain. Which might not be a problem. Though would only one set of carriages on each side for the current rebuild be enough with only 150 -175mm of travel.
    Hope to get some drawings done tonight and trying to figure out a space issue with the required space for the Z leadscrew and backlash nut/mounting bracket versus the height that the rails and carriage require to function. Looks like I will be needing to mill some stock down with not only datum slots but also with channel to allow space for the screw. I have access to 12mm Alli' for sure and might have access to thicker. Having said that would milling the 12mm down to a 6mm channel in the centre reduce strength below the desired levels? I am still learning metal and it tolerances and what it can and can not do. Which is different then what i do with metal for making reeds in many fashions as there you want the metal to bend.
    Michael
    Hi Micheal,
    First depends what you intend to do with the machine regards the plate thickness. I've made various differant Z axis but only one that was made with thin plate. This had a long 220mm travel and was mainly intended to cut soft materials like foam,plastics etc. It was made with with cast off's and scrounged parts that the owner and me between us gatherd (Hence thin plate was used).
    It's not ideal for cutting hard materials but the guy does cut every thing from foam to Ali with it. . . It's a belt driven machine as well, very quick and accurate.!! . . I love this little machine "The Cavemill" was so much fun to make and resonably cheap being made mainly from scrounged bits. Attached a few pics of the Z axis and some stuff it's cut.
    I love making "Junk yard dog's" I'm just finishing off another I'll post a pic of.
    Personaly I dont like to use anything below 19mm for a Z axis that is intended to cut hardwoods or Ali. If your using profiled rail and intend to cut datum points and slots for screw etc then you really do need the 19mm else your weakening the structure. Again depends on intended use but for hardwoods and Ali using Profiled rail then 19mm is minimum IMO.
    Also I wouldn't recommend using 1 carraige per side no matter what thickness material, it's false economy because it will flex badly and you'll end up making it over again.! . . Esp at the travels your wanting.
    Imo the Z axis is one if not "THE" most important parts on the machine, remember doesn't matter how strong you build the rest of the machine if the Z aixs flexs you'll have BAD results.!! . . . It's also one area everybody new under estimates.
    Regards travel most of my Z axis tend to be between 120-150mm the one in the previous pics had 150mm if I remember correctly.??
    Attached a few pics of Zaxis made all ways. All built depending on machine and material requirements. Hope these will help you design something to full fill your needs.
    Cheers.
    PS: The upstands on the junkyard pics are temps just for affect to give idea too intended owner and have since been made lot shorter.
    Edit: Added Cavemill pics of stuff cut.
  1. CNC Build - TEP milling machine conversion
    By craynerd in forum Gantry/Router Machines & Building
    Last Post: 06-07-2015, 02:09 AM
  2. Someone to help me build a machine
    By mandev in forum Gantry/Router Machines & Building
    Last Post: 29-01-2014, 02:07 PM
  3. DIY Machine to Build?
    By paulkane1 in forum Gantry/Router Machines & Building
    Last Post: 03-12-2012, 02:24 PM
  4. NEW MEMBER: Second machine build
    By tmsboss in forum New Member Introductions
    Last Post: 04-09-2010, 01:11 PM
  5. Best Type of Machine to Build?
    By Kevin in forum Gantry/Router Machines & Building
    Last Post: 05-08-2009, 02:50 PM
