  1. #10
    Quote Originally Posted by m.marino View Post
    Due to problems (flex of Y axis and Z axis dropping up to 1.5mm from a set position)
    The Zaxis dropping most likely won't be due to weak design problem but more probably an electrical problem, possibly a weak or under powered motor thou you'll still have the same problem if not changed.
    Other than what marks pointed out then there's not much more to see or say.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. CNC Build - TEP milling machine conversion
    By craynerd in forum Gantry/Router Machines & Building
    Last Post: 06-07-2015, 02:09 AM
  2. Someone to help me build a machine
    By mandev in forum Gantry/Router Machines & Building
    Last Post: 29-01-2014, 02:07 PM
  3. DIY Machine to Build?
    By paulkane1 in forum Gantry/Router Machines & Building
    Last Post: 03-12-2012, 02:24 PM
  4. NEW MEMBER: Second machine build
    By tmsboss in forum New Member Introductions
    Last Post: 04-09-2010, 01:11 PM
  5. Best Type of Machine to Build?
    By Kevin in forum Gantry/Router Machines & Building
    Last Post: 05-08-2009, 02:50 PM
