Thread: 1st Build, Second machine
14-10-2011 #11
It's just occurred to me that your gantry has very poor torsional stiffness. Normally that's not a problem as with two ballscrews it can't twist, however with only one nut in the middle when the cutter is near either edge of the bed the gantry can twist causing deflection. Given the tolerances you require that could cause problems. You're essentially only relying on the joint between the gantry back plate as sides, so I'd be inclined to reinforce that. The rail mount blocks will help...also don't remember what joining the bottom of the gantry sides, that will make a difference.
CNC Build - TEP milling machine conversion
By craynerd in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 06-07-2015, 02:09 AM -
Someone to help me build a machine
By mandev in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 29-01-2014, 02:07 PM -
DIY Machine to Build?
By paulkane1 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 03-12-2012, 02:24 PM -
NEW MEMBER: Second machine build
By tmsboss in forum New Member IntroductionsReplies: 1Last Post: 04-09-2010, 01:11 PM -
Best Type of Machine to Build?
By Kevin in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 05-08-2009, 02:50 PM
