    Lives in East Lothian, United Kingdom. Last Activity: 9 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,988. Received thanks 373 times, giving thanks to others 9 times.
    You need to think about what you're planning on doing with the rotary table.
    A 3 Jaw self-centreing will be better if you'll be doing lots of round/hex bits, but a 4 jaw independant does give you more flexiblity, however it will mean you become very proficient in the use of a dial gauge! I've never used a 4 jaw self centreing chuck, but it could be a good compromise.
    Personally, I've not got any jaw chucks for either of my rotabs, and I've never missed having one for what I do with them. Most of the bits I do get held via T-nuts, however, I do have an expanding mandrel holder that fits in the rotab taper which is very handy.
  2. Quote Originally Posted by m_c View Post
    The first job i need to do is to cut 12 tooth 3m htd pulley from steel bar so I'm thinking about holding a stock in a chuck. Another issue is to produce a cutter to cut 3m hdt profile. I searched internet but it looks like the only option is to make cutter myself
    Quote Originally Posted by wiatroda View Post
    That's what I did for XL pulleys ... but then that's only a trapezium.
    Small ball nose cutter and several passes to get the right profile? Would take ages but if it's a one off why not?
    P.S. I've got some 3m HTD pulleys if you're interested... I'll go and check what sizes.
  4. Quote Originally Posted by Jonathan View Post
    The profile for 3m looks like this
    What about to drill 12 holes 1.8 mm dia then turn it to proper outside size???? Eventually tweak corners a bit
    Jonathan I have those pulleys, but I need something like shaft ending with a pulley on the end. The stock one are not any good, I tried:sad:
    That looks like the profile for the belt, not the pulley. There's generally a small difference.
    I've seen pictures of it done by drilling, so I suppose it's worth a try. I can't think of any reason for the holes not to be accurate. I would use 1.9mm as you'll be a bit stuck if the cut-outs are too small and it does not fit.
    You might be able to 'tweak' the corners well enough with a chamfer. Maybe put it in a lathe and spin whilst holding a piece of wet and dry to it.
  1. Diy 4th axis rotary table using 100mm chuck with minimal backlash
    By kingcreaky in forum Linear & Rotary Motion
    Last Post: 05-09-2013, 01:03 PM
  2. CNC Rotary table/lathe head indexing
    By Kwackers in forum Electronic Project Building
    Last Post: 09-12-2011, 03:33 PM
  3. Mounting a chuck on a Rotary table
    Last Post: 02-09-2010, 07:23 PM
  4. Rotary Table CNCing
    By irving2008 in forum Gantry/Router Machines & Building
    Last Post: 19-02-2010, 11:57 PM
  5. Setting up work on the rotary table
    Last Post: 09-01-2010, 10:27 AM
