Definately two drivers with two motors. It's theoretically possible to do it with one ... but don't go there!
Those drivers are not very good at all - only 27 volts. You should get at least 50V, or 75V. That will be more like £200 for the drivers and something for the breakout board ... there's a cheap 5-axis one on eBay.
One breakout board will suffice, unless you run out of inputs later on. You just need as many power supplies as required to get sufficient power to the motors. I used a 500VA, 75V (when rectified) transformer for 4 motors ... it's ok on 5 too.
CY, 4-core cable 1.5mm^2.
Don't worry about the electronics, I'm sure I/we can assist...
Stepping Motors & Drivers
By irving2008 in forum Stepper & Servo MotorsReplies: 3Last Post: 28-04-2015, 09:37 PM -
have you put ball screws on an X2plus?
By bmbaz in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 14-05-2014, 06:56 PM -
buying ball screws
By bmbaz in forum Marketplace DiscussionReplies: 2Last Post: 10-05-2014, 03:57 PM -
2x Motors, 2x drivers. How about breakout?
By Tenson in forum Motor Drivers & ControllersReplies: 2Last Post: 20-09-2012, 03:21 PM -
Best way to machine ball screws?
By Ross77 in forum Lead Screws, Nuts & SupportsReplies: 34Last Post: 17-06-2012, 05:10 PM
