01-09-2011 #12
If you look at the graphs, wiring in paralel doesn't actually give you a big torque speed advantage. OTOH, experience shows you will get a lot more heat that needs to go somewhere.
Consider where you will dump that extra heat.
As I understand it, any flaws in the soft iron motor lamination act as little, shorted out, single turn, transformer coils. When you switch the motor windings you generate "eddy currents" around those flaws which heat the lamination. Halving the coil inductance boosts the eddy current heating.
Some reckon that the gain ain't worth the pain.
Matching Drivers with Steppers
By hoppo in forum Motor Drivers & ControllersReplies: 4Last Post: 21-11-2012, 01:19 PM -
Optimum voltage for M60STH88-3008DF steppers and 752 drivers?
By Mad Professor in forum Stepper & Servo MotorsReplies: 6Last Post: 26-08-2012, 09:38 PM -
Any one used drivers and steppers from CNC4you
By sebring115 in forum Motor Drivers & ControllersReplies: 14Last Post: 30-11-2011, 11:32 PM -
Has anyone used these steppers or drivers?
By Jonathan in forum Stepper & Servo MotorsReplies: 2Last Post: 24-03-2011, 02:24 PM -
Steppers and drivers
By Davidh in forum Motor Drivers & ControllersReplies: 3Last Post: 12-06-2009, 05:59 PM
