To be honest I have found that most of these carbide engraving cutter take the tip off far to easily, makes sense when you think about it as carbide is a sintered powder and has no grain as such.
Recently I have been grinding my own up from 6mm HSS drill blanks, don't last as long as carbide but once you have the D shape they cam be resharpened in about 2 minutes. Plus bit is you don't scrap a job because it takes the tip off 1 hour into a 3 hour job.
8" x 3/4" all done with HSS tool.John S -
15-08-2011 #2
Think I've seen that photo before somewhere ...
I'll have to try the drill regrinding suggestion. I've kept any drills I have snapped (thankfully few) to regrind into spot drills. They seem ideal for that.
Oh just noticed you said drill blanks, not drills. Just a D shape?
V Bit Cutters in Aluminium?
By Washout in forum Tool & Tooling TechnologyReplies: 3Last Post: 06-03-2014, 03:29 PM -
machining aluminium with 1.5kW spindle
By routercnc in forum Spindles & Drive MotorsReplies: 13Last Post: 15-02-2014, 02:55 AM -
aluminium machining
By drumsticksplinter in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 15-03-2013, 12:19 AM -
RFQ: Aluminium frame Machining
By mZeles in forum Projects, Jobs & RequestsReplies: 4Last Post: 27-12-2012, 08:17 PM -
Machining Aluminium
By Steff in forum Metalwork DiscussionReplies: 7Last Post: 14-11-2012, 12:48 PM
