Hi, I'm looking for someone who can machine a gear selector assembly for me. I can supply the models in IGS, STL etc and the target material is 6082 which I can supply if required.
The main part requires machining operations on all 4 faces and includes a hemispherical cutout. There are an additional 3 parts only one of which can be described as complex.
The largest part has a bounding box size of approx 100m x 120mm x 25mm.
Many thanks, Max
27-08-2011 #2
Drawings (even if they're only sketches), along with an idea of the tolerances you are looking for, would be handy if you have them available.
30-08-2011 #3
Thanks AdieR - Jonathan is handling the work for me.
stability - monolith vs. two-part assembly
By dsc in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 24-10-2012, 03:03 PM -
Mill gear box oil
By abfa9358 in forum Machine DiscussionReplies: 8Last Post: 15-05-2011, 04:48 PM -
My first gear, a deadbeat escapement gear for my clock
By clockman in forum Woodworking Project ShowcaseReplies: 9Last Post: 30-01-2011, 11:39 PM -
Gear cutting
By John S in forum CAD & CAM SoftwareReplies: 7Last Post: 03-10-2010, 07:55 PM -
Where to get gear blanks in UK...
By irving2008 in forum Machine DiscussionReplies: 4Last Post: 03-01-2010, 03:19 PM
