    Quote Originally Posted by Stickio View Post
    I am not sure if my steppers will be up to the task of moving the heavy gantry around, I would really like to be able to take some pretty fast and aggresive cuts on wood and acrylic, I'm thinking quick direction changes in the X direction might be a problem?
    I'm using the same steppers for my machine which is bigger so probably heavier and they work fine. I used 10mm pitch, which helps as 1/4 the K.E. in the screw and on the X-axis rotated the ballnuts which helps even more...If you want high feedrates then get 10mm pitch screws and ideally timing belt/pulleys not direct drive to get the optimal ratio. I'm running the motors on 75V which is necessary to get high enough torque at high speed.
    Will I have problems with the X and Y leadscrews whiping?
    Depends how fast is 'pretty fast'! Y will be fine. If you use 10mm pitch screws then the RPM of the screw is of course halved, so you can go twice as fast before whipping.
    X is 1500mm with angular contact on one end and single bearing on the other, 5mm pitch:
    (approximately)
    16mm diameter critical speed is 5000mm/min
    20mm diameter 6000mm/min
    25mm diameter 7700mm/min
    Double those if you use 10mm pitch. Those feedrates are achievable with the 3nm motors .. I got much more.
    On that size machine I would *definately* go for two screws on the X-axis to prevent racking especially as you want to take 'agressive cuts'.
    Your Z axis linear bearing blocks look too close together for that travel.
    Ugg just checked my drivers and they are only rated at 50V, looks like im going to have to start replacing electronics anyway.
    I am starting to have a change of heart, the way I see it at the moment is that I have a machine that is working ok at the moment so I am not in a huge rush to get this one up and running so as James has pointed out lets do it right the 1st time. I will tweak the design to include twin X screws that way I can order the steel in and get on with making the frame while I save up for other bits.
    Where did you get your 75V power supply and drivers from was it zapp?
    Didnt think about the Z backdrive, maybe some sort of solenoid brake that retracts in the powerd up state and locking the z when controller is switched off. If I dont do something like that I know for sure I will forget and end up ruining something :)
    For those who have not seen it before here is the pully system I was talking about.
    At least with replacing the drivers and power supply I wouldnt have any excuses not to make a scratch built cnc mill I've been wanting to build, cant have those bits sitting there gathering dust :P
    Drivers were from Zapp - their service is excellent, but you can now get them a fair bit cheaper on eBay. I made (or rather assembled, there's nothing to it really) the power supply from a 500VA toroidal transformer on eBay, bridge rectifier and a couple of capacitors. Google it and I'm sure you'll find the general idea...
    Could do, I just quite literally stick a spanner in the works if required!
    I reckon the pulley diagram you posted wouldn't work very well because the acute angle between the crossing wires is very small. Too tired to calculate it properly now, but I'm pretty sure you'd want the same sort of thing but with one pulley on each corner of the frame, like on a drawing board ruler...
    Quote Originally Posted by luke11cnc View Post
    their are people here that will cut/machine items at a cost for you.
    That's me...
    Hi Barry
    I dont think you would have any problems with racking if you have a single drive on the x axis. Your gantry is identical to mine and I get no problems even on aggressive cuts.
    I dont see any advantage of a 10mm pitch on the z screw. x and y speed are important but how often do you need to plunge into the workpiece at high speed? With a 5mm pitch you will not need a brake (or a spanner).
    It looks good to me, but then I'm biased :)
    It's good to have high speed Z if you're drilling PCBs, but that's about the only thing I can think of.
    Quote Originally Posted by pavlo View Post
    My Z-axis, with 2.2kW spindle, has a 5mm pitch and does drop ... it obviously depends on the weight of the axis.
  1. Replies: 1
    Last Post: 01-03-2014, 01:31 AM
  2. BUILD LOG: Steel Framed CNC router
    By Joe in forum DIY Router Build Logs
    Last Post: 23-06-2013, 10:45 PM
  3. BUILD LOG: Formed steel cnc router
    By sbams in forum DIY Router Build Logs
    Last Post: 07-03-2013, 02:00 AM
  4. BUILD LOG: Steel Framed Router
    Last Post: 14-09-2011, 06:51 PM
  5. BUILD LOG: My steel framed router
    By pavlo in forum DIY Router Build Logs
    Last Post: 06-03-2011, 10:08 PM
