Thread: Steel Router 610 x 1220 x 200
Drivers were from Zapp - their service is excellent, but you can now get them a fair bit cheaper on eBay. I made (or rather assembled, there's nothing to it really) the power supply from a 500VA toroidal transformer on eBay, bridge rectifier and a couple of capacitors. Google it and I'm sure you'll find the general idea...
Could do, I just quite literally stick a spanner in the works if required!
I reckon the pulley diagram you posted wouldn't work very well because the acute angle between the crossing wires is very small. Too tired to calculate it properly now, but I'm pretty sure you'd want the same sort of thing but with one pulley on each corner of the frame, like on a drawing board ruler...
That's me...Last edited by Jonathan; 17-08-2011 at 08:55 PM.
17-08-2011 #2
Hi Barry
I dont think you would have any problems with racking if you have a single drive on the x axis. Your gantry is identical to mine and I get no problems even on aggressive cuts.
I dont see any advantage of a 10mm pitch on the z screw. x and y speed are important but how often do you need to plunge into the workpiece at high speed? With a 5mm pitch you will not need a brake (or a spanner).
It looks good to me, but then I'm biased :)
18-08-2011 #3
WANTED: 3 bits of 250 by 1220 by 40mm t-slot, 1220 16X5 threaded rod and isel ballscrew, plus
By nobby in forum Items WantedReplies: 1Last Post: 01-03-2014, 01:31 AM -
BUILD LOG: Steel Framed CNC router
By Joe in forum DIY Router Build LogsReplies: 14Last Post: 23-06-2013, 10:45 PM -
BUILD LOG: Formed steel cnc router
By sbams in forum DIY Router Build LogsReplies: 4Last Post: 07-03-2013, 02:00 AM -
BUILD LOG: Steel Framed Router
By GTJim in forum DIY Router Build LogsReplies: 52Last Post: 14-09-2011, 06:51 PM -
BUILD LOG: My steel framed router
By pavlo in forum DIY Router Build LogsReplies: 17Last Post: 06-03-2011, 10:08 PM
