Thread: Steel Router 610 x 1220 x 200
Hi Barry
I dont think you would have any problems with racking if you have a single drive on the x axis. Your gantry is identical to mine and I get no problems even on aggressive cuts.
I dont see any advantage of a 10mm pitch on the z screw. x and y speed are important but how often do you need to plunge into the workpiece at high speed? With a 5mm pitch you will not need a brake (or a spanner).
It looks good to me, but then I'm biased :)
18-08-2011 #2
WANTED: 3 bits of 250 by 1220 by 40mm t-slot, 1220 16X5 threaded rod and isel ballscrew, plus
By nobby in forum Items WantedReplies: 1Last Post: 01-03-2014, 01:31 AM -
BUILD LOG: Steel Framed CNC router
By Joe in forum DIY Router Build LogsReplies: 14Last Post: 23-06-2013, 10:45 PM -
BUILD LOG: Formed steel cnc router
By sbams in forum DIY Router Build LogsReplies: 4Last Post: 07-03-2013, 02:00 AM -
BUILD LOG: Steel Framed Router
By GTJim in forum DIY Router Build LogsReplies: 52Last Post: 14-09-2011, 06:51 PM -
BUILD LOG: My steel framed router
By pavlo in forum DIY Router Build LogsReplies: 17Last Post: 06-03-2011, 10:08 PM
