Thread: X2 change balls crews or not?
15-08-2011 #1
Hi, can anyone help, I have just bought a sx2 mill and I want too convert it but I'm unsure as to wether I can keep the original screws or I need to change them and if so which ball screws. Any help really appreciated thank you
16-08-2011 #2
if you shop around i'm pretty sure you can get a kit of parts to convert these mills, and definately ballscrews.
17-08-2011 #3
Thank you but I'm hoping to do this without a kit. From what I have seen it's possible to leave the original screws and attach them using lovejoy connectors, but this still leaves the problem of the Z axis and the length of the lead screw for that and the size of the stepper motors.
17-08-2011 #4
things to consider on ballscrews over leadscrews are, better power transfer on a ballscrew, greater accuracy, zero backlash, trouble free maintenance.
The Following User Says Thank You to i2i For This Useful Post:
17-08-2011 #5
Also remember that ballscrews can backdrive (depending on the lead angle) which can make using the machine manually more difficult. You may have to lock the slides. I think it's worth considering as for simple parts it's sometimes easier just to do it manually...
The Following User Says Thank You to Jonathan For This Useful Post:
17-08-2011 #6
17-08-2011 #7
17-08-2011 #8
Thank you both for your input, a lot to think about. It's been over 30yrs since I used a mill or lathe manually and the learning curve seem a lot steeper now. Could I ask, Jonathan, how much accuracy do you think you have lost, if any, by using the lead screws? And did you lose any of the table range?
Belts or Balls getting me Screwed up! Help I need advice Please.
By longy in forum Belt Drive, Pulleys & TimingReplies: 15Last Post: 15-04-2014, 02:46 PM -
ballnut - balls back in via the side cover and using less balls than original
By dsc in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 16-11-2013, 04:27 PM -
How to get the balls back in a ballnut?
By Shinobiwan in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 24-03-2013, 04:35 PM -
Balls, balls and balls
By Swarfing in forum Marketplace DiscussionReplies: 15Last Post: 21-03-2013, 08:45 PM -
Lost my balls!!!
By danielbriggs in forum Lead Screws, Nuts & SupportsReplies: 26Last Post: 19-08-2010, 02:41 PM
