Thread: Understanding the bearing block
28-08-2011 #10
Possibly, but it's not ideal. The problem with a collar is, similar to the thrust bearings, it may be skewed on the shaft. A collar that clamps onto the shaft (ring with slit, bolt through slit to squash it) would be better. I would stick with having a thread. It depends what you're doing with the machine. If you're only cutting PCBs then pretty much anything will work ...
WANTED: BK12 Bearing Block Wanted - 1 off
By EddyCurrent in forum Items WantedReplies: 7Last Post: 11-03-2017, 08:52 PM -
Help needed with understanding accuracy in measuring tools. I want to go straight :-)
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 25Last Post: 01-10-2013, 05:17 PM -
understanding stepper motor ratings.
By jcb121 in forum General ElectronicsReplies: 3Last Post: 30-09-2013, 04:06 PM -
WANTED: EPS Block
By cropwell in forum Items WantedReplies: 2Last Post: 24-05-2013, 12:09 AM -
Help understanding the software side of cnc routing.
By don_jarr in forum CAD & CAM SoftwareReplies: 5Last Post: 23-06-2011, 01:13 PM
