Thread: Steel Framed Router
02-09-2011 #14
No Switch's.! . . Not even Home switch's.?
Next to touch probe the Home switch's are the best and most time saving thing you could put on your machine. Can't count the number of times they'e got me out of trouble. . . must be in the hundreds.
They must have saved me hundreds of pounds in material that would have been lost or wrecked due to loss of position when an error or tool breaks. . . . . Nothing worse than a tool braking after several hours cutting one job. . . No problem and Simplizz's with home switch's.
Send machine home to reset it's position, rewind the code to just before the tool broke and away you go again. . . Brilliant.
No limit switch's on the large machine, IMO you can live with out them on larger machines, soft limits are more than good enough and in the 3yrs using the big machine I've never hit the hard stops or the soft limits other than me trying to drive the thing into them.
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
BUILD LOG: Steel Framed CNC router
By Joe in forum DIY Router Build LogsReplies: 14Last Post: 23-06-2013, 10:45 PM -
BUILD LOG: Formed steel cnc router
By sbams in forum DIY Router Build LogsReplies: 4Last Post: 07-03-2013, 02:00 AM -
BUILD LOG: My steel framed router
By pavlo in forum DIY Router Build LogsReplies: 17Last Post: 06-03-2011, 10:08 PM
