Thread: Steel Framed Router
14-09-2011 #18
Thank you... if you've not got the kit to make them yourself then I can make them for you. Let me know if you're interested and I'll work out the price for what you need.
The simple answer is it depends. If it's a small diameter screw, or you want a very high feedrate, then yes you'll gain at 1m. See what I put about critical speed in post 39. You do save by not buying the bearing blocks and you can get away without end machining on the screw. This is good since it makes the size/pitch screws that are not on eBay more reasonably priced.
If it's a 25mm screw then the rotating nut setup I made has the same inertia as about 700mm of the screw, so you wont gain anything below that. The critical speed of a 700mm long 25mm diameter screw is very high anyway, so you wouldn't need to use a rotating nut anyway. I've not worked out the moment of inertia of the 16/20mm version yet.
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
BUILD LOG: Steel Framed CNC router
By Joe in forum DIY Router Build LogsReplies: 14Last Post: 23-06-2013, 10:45 PM -
BUILD LOG: Formed steel cnc router
By sbams in forum DIY Router Build LogsReplies: 4Last Post: 07-03-2013, 02:00 AM -
BUILD LOG: My steel framed router
By pavlo in forum DIY Router Build LogsReplies: 17Last Post: 06-03-2011, 10:08 PM
