Thread: where to start?
Nah, can do better than that. Give me a grand and I'll prove it :lol: You and JohnS reckon I'll be a millionaire 'soon enough' so I'm sure you'd get the money back!
The critical point is '18mm mdf ... nothing more than that', so the machine does not need to be massively rigid and a 50mm Z-axis should be fine. If you're sticking to that budget then start with a simple 8x4 rectangular steel frame mounted on a strong table or the floor which shouldn't cost much. Use linear bearings from ebay (linearmotionbearings2008), or to get it cheaper explore one of the other methods.
No mention of required feedrate, so I'm sure 3nm motors would be plenty... I reckon it's possible though in my opinion you'd be much better off in the long run spending more to start with.
By all means cut corners, as long as they're square. :naughty: Not going to be much of a frame without corners. Mine was far too big and too weak to start with.Last edited by Jonathan; 05-09-2011 at 08:36 PM.
06-09-2011 #2
Thanks Guys, been doing more research up until the small hours and starting to get a better undertsanding.
Whats the general rule for frame size vs the actual cutting area? I'm limited for space so I'm hoping that 10' x 5.5 will be enough for 8' x 4. I only ask because I was looking at the linear bearings on ebay and the nearest size I'll be needing are 2750mm which is a fair bit past the actual cutting size.
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start
By martin54 in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 22-09-2012, 11:29 AM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM -
NEW MEMBER: Were do I start?!
By tonygagey in forum New Member IntroductionsReplies: 4Last Post: 07-08-2010, 07:55 PM -
Where to start?
By ricey3 in forum Computer SoftwareReplies: 10Last Post: 25-10-2009, 08:01 PM
