Thread: "DeusEx"
    thanks guys! :-)
    I'm fairly happy with the state of the design for Y but the Z still needs some more work. Looks like about 150mm from the ball nut that moves the Y to the centre line of the spindle. Using HWIN 15mm rails would drop that to around 130mm, but 20 mm of those numbers are the spindle mounting plate! The Z ball nut is 94mm from the spindle centre. But it's difficult to see with these crayon drawings :rofl:
    As long as the ballnut is directly between (zero distance measured parallel to X-axis ... hard to describe) the two Y-axis rails then I think 130mm will be fine as the aluminium plate in between is very strong and should not flex much. If you have not already try setting the rails/blocks on the Z-axis into the plate - i.e. mill a slot for the rail and pocket for the blocks. That will reduce the distance further though you'll have fun fitting the Z ballnut as that will also require a cutout.
  1. "Hacking" and "Modding"
  2. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  3. Replies: 4
    Last Post: 28-09-2012, 12:06 PM
  4. "Racks" VS "ball screw"
  5. Replies: 1
    Last Post: 25-12-2010, 06:05 PM
