    Quote Originally Posted by obsolete View Post
    I'll buy and assemble everything myself but anything that needs "making" (cutting out parts from MDF from a plan, machining custom motor mounts and so on) I will get local tradespeople to do in the interests of expediency and quality.
    This reads like you Intend using MDF as the machine frame.? . . . If so then I urge you to re-think, yes I know folks use it often but honestly it's false economy and will give far inferior performance.
    And finally my budget excluding computer and software but including all other electronics is …
    £1000
    Yes it's do-able at this size, thou will still need carefull buying of components etc and clear accurate idea/plan of the machine required.
    It's very easy to buy unsuitable components and under estimate machine frame construction needs or materials and with a budget of £1000 you haven't got much wiggle room.!!
    To save me lots of writing read post #8 about half way thru. http://www.mycncuk.com/forums/showth...where-to-start
    Cheers.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #2
    Hi
    Thanks for your reply. That's great to hear. £1000 doable but not a breeze sounds like a good challenge. I haven't made the decision to use MDF at all I just used it as an example as I have seen it used. Lots of writing not necessary, a brief answer was all I was after! I will dive into the thread you've linked to.
    Thanks again
    Jim
  1. Free Machine Plans
    By CRP in forum Machine Frames & Beds
    Last Post: 24-07-2013, 06:32 PM
  2. Change of plans: basements
    By Rogue in forum Workshop & Equipment
    Last Post: 28-03-2013, 10:38 PM
  3. 3040 size router plans?
    By m_c in forum Gantry/Router Machines & Building
    Last Post: 24-06-2012, 04:15 PM
  4. Trying to find a kit or plans to build.
    By don_jarr in forum Gantry/Router Machines & Building
    Last Post: 16-06-2011, 04:28 PM
  5. Most recommended plans??
    By crazy horse in forum Gantry/Router Machines & Building
    Last Post: 03-07-2009, 02:45 PM
