  1. #6
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,984. Received thanks 369 times, giving thanks to others 9 times.
    Looks fairly easy to do, however an idea of tolerances are needed.
    Is the part to be a pressfit into the roller, or a slight clearance fit to allow it to be glued/bonded in?
    Is the recess in the rollers consistent?
    i.e. are they a consistent size, and true.
    If they're not, then it may be better to machine the shoulder, press/bond them in, then machine the through hole/bearing recess/belt groove to ensure things run true.
    I'm guessing the bearing will be a pressfit?
    Also, how many?
    It's not a hard part to make, however there's lot of potential for things to not be quite right without the above information.
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. CNC Routing Nylon 6 Material
    By Steff in forum General Discussion
    Last Post: 20-10-2012, 11:39 PM
  2. Delrin & Nylon S & F please
    By craigrobbo in forum Machine Discussion
    Last Post: 21-07-2012, 12:19 PM
  3. RFQ: Bracket parts from Nylon
    By egimson in forum Projects, Jobs & Requests
    Last Post: 18-04-2012, 12:20 AM
  4. RFQ: Parts CNC machined from Nylon
    Last Post: 02-04-2012, 08:40 PM
  5. roller blind style covers
    By tumutbound in forum General Discussion
    Last Post: 26-06-2009, 11:31 AM
