19-09-2011 #6
Looks fairly easy to do, however an idea of tolerances are needed.
Is the part to be a pressfit into the roller, or a slight clearance fit to allow it to be glued/bonded in?
Is the recess in the rollers consistent?
i.e. are they a consistent size, and true.
If they're not, then it may be better to machine the shoulder, press/bond them in, then machine the through hole/bearing recess/belt groove to ensure things run true.
I'm guessing the bearing will be a pressfit?
Also, how many?
It's not a hard part to make, however there's lot of potential for things to not be quite right without the above information.
The Following User Says Thank You to m_c For This Useful Post:
CNC Routing Nylon 6 Material
By Steff in forum General DiscussionReplies: 5Last Post: 20-10-2012, 11:39 PM -
Delrin & Nylon S & F please
By craigrobbo in forum Machine DiscussionReplies: 2Last Post: 21-07-2012, 12:19 PM -
RFQ: Bracket parts from Nylon
By egimson in forum Projects, Jobs & RequestsReplies: 4Last Post: 18-04-2012, 12:20 AM -
RFQ: Parts CNC machined from Nylon
By egimson in forum Projects, Jobs & RequestsReplies: 3Last Post: 02-04-2012, 08:40 PM -
roller blind style covers
By tumutbound in forum General DiscussionReplies: 2Last Post: 26-06-2009, 11:31 AM
