Thread: cutter chipload
does anyone hve a chart of approxmate chiploads for correct cutting of various woos?
	17-09-2011 #2
GWizard is your new friend:
http://www.cnccookbook.com/CCGWizard.html
It depends on the cutter diameter as clearly smaller cutters will deflect/snap if you use too high a chipload. As a rough guide:
MDF:
12mm cutter 0.4mm chip
6mm cutter 0.3mm chip
3mm cutter 0.25mm chip (maybe less)
Plywood:
12mm cutter 0.42mm chip
6mm cutter 0.35mm chip
3mm cutter 0.3mm chip (maybe less)
(Can give more examples if required)
In reality you may end up using a fair bit less than these values as the machine may not be able to achieve these feedrates.
fly cutter advice please
By luke11cnc in forum Tool & Tooling TechnologyReplies: 13Last Post: 07-12-2014, 01:38 PM -
Skimming yer bed.... does anyone use a fly cutter?
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 08-09-2013, 04:57 PM -
cutter for MDF
By deannos in forum Tool & Tooling TechnologyReplies: 5Last Post: 16-10-2011, 09:33 PM -
First Plasma Cutter
By antsals in forum Plasma Table MachinesReplies: 3Last Post: 16-05-2011, 07:58 AM -
Chipload and DOC for small endmills
By Jonathan in forum Tool & Tooling TechnologyReplies: 15Last Post: 16-01-2011, 04:12 PM
