    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Just a quick check before I buy too many or too few volts.
    Needing a new toiroid for the lathe, and need to keep below 50V (limit of the Geckos), so aiming for 46V(ish) sounds good to me, and gives me about a 10V increase.
    So, with those figures, and ye olde root2, means in a perfect world I need about 32V, but giving an allowance for mains drift, does a toiroid secondary of 30V sound good?
    Also, is there any practical difference between going for 2x15, or 2x30 secondaries?
    2x15, or 2x30 both sound good to me.
    2x15 gives you the option of getting half the voltage for er, something...?
    Bear in mind that due to the voltage drop from the bridge rectifier, and the transformer regulation (and numerous other effects) you will get less than root 2 times the rated voltage. I think you'd get away with a 35V transformer (e.g. http://www.rapidonline.com/Electrica...nsformer-82719). Worst case scenario is you have to reduce the voltage a bit. That's easy enough - just wind a few turns of THICK wire on to the transformer and connect it in series with the output. If you put the wire the 'wrong' way round the current induced in it is 180° out of phase with the main winding, so it opposes the main current and reduces the output voltage. Side effect is that piece of wire gets a bit toasty - hence the thickness.
    The only thing to watch out for is the VA rating. Most toroid transformers split their rating with their windings. Say a 300VA transformer with a single secondary would be rated at 300VA, but if it has two secondaries it would be 150VA per winding. This might make a bit of difference for your selection process.
    Ian
    M_c will be using both windings though (in either series or parallel), so will still get the full rating of the transformer.
    Both windings will be getting used in series or parallel, depending on which tx I get.
    I'm going to get a switched mode Din rail 12V PSU for 12V needs to simply things, so don't need any extra windings.
    35V is cutting it a bit close. It theoretically gives 49.5V rectified, less 1.4V for the bridge, gives about 48V, but that's at a rated input of 230Vac, so by the time you allow 10% for mains variation, it takes you well over 50V.
    Think I'll go up one size at the same time (existing TX was 160VA), to allow for future additions, so will probably go for a 225VA.
    Airlink is the cheapest supplier I've found, but need to check on postage, as I need other bits they don't do.
    Luke11cnc has one that might be suitable going spare. I've got a few too...
    It depends...
    Clearly 30V transformer is the safest option - the margins are a bit close otherwise. I probably shouldn't recommend more but if it was me I'd get the 35V and if required do what I said in the last post to reduce the output a bit. Then maybe run the motors with oscilloscope on power supply just to be sure.
    Airlink looks to have £9 postage, which makes them more expensive than Rapid electronics ... if it's some other electronics bits you need then Rapid is bound to have them which might even get you to the free postage boundary.
    I've just been searching for the extra bits, and have given up on the search for tonight.
    Capacitor calcs work out at around 12500uF, and 63V seems to be the nearest, but neither RS or Rapid have anything suitable in stock.
    Farnell? They've got a good selection of transformers too...
    Put two or three 4700uF in parallel to get round the lack of stock. That also gets lower ESR which is a slight advantage.
    It's safer to go with two 15 V windings in series rather than two 30 V in parallel just in case the windings don't have exactly the same number of turns. I know they should but......
    Russell.
    Just got the new toroid in place, and it's giving me 44V. Slightly lower than what I ideally wanted, but still 8V higher than the previous, so I should be able to eek a little bit more speed out the steppers.
  1. screening / glitchy operation - sanity check
    By dsc in forum General Electronics
    Last Post: 01-12-2013, 11:35 PM
  2. Toroidal Transformer
    By Carlb1058 in forum General Electronics
    Last Post: 17-08-2013, 06:54 AM
  3. maximum deflection - sanity check
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 11-02-2013, 09:33 AM
  4. Different voltages on different steppers
    By Lovre in forum Motor Drivers & Controllers
    Last Post: 12-12-2012, 11:28 PM
  5. sanity check - constant running, loads and more
    By dsc in forum Stepper & Servo Motors
    Last Post: 26-11-2012, 12:26 PM
