    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    No.
    I seem to have a lack of insulated proves for the multimeter just now, so just measured to make sure the voltage wasn't too high. The Gecko's are good for 50V, so a 6V safety margin should be good enough.
    You are probably OK. However, the reason I asked is that the UK mains voltage is 230 V with a tolerance of +10%, -6%. So, if the mains voltage was 6% low when you made the measurement, then the voltage you get at maximum mains voltage will be over 50 V. An unlikely but possible situation.
    Russell.
    If it's for the Gecko G540 then this will do the job. http://www.airlinktransformers.com/t...with-leads.asp
    I've just built a control box for someone using this toroid and It is giving a steady 47V and my mains input voltage is quite high due to the fact I live bang next to the sub station.
    I've had it on test know for several weeks and no issues's so far.
    EDIT: Doh . . . didn't read all the post's did I.!! . See your sorted.
  1. screening / glitchy operation - sanity check
    By dsc in forum General Electronics
    Last Post: 01-12-2013, 11:35 PM
  2. Toroidal Transformer
    By Carlb1058 in forum General Electronics
    Last Post: 17-08-2013, 06:54 AM
  3. maximum deflection - sanity check
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 11-02-2013, 09:33 AM
  4. Different voltages on different steppers
    By Lovre in forum Motor Drivers & Controllers
    Last Post: 12-12-2012, 11:28 PM
  5. sanity check - constant running, loads and more
    By dsc in forum Stepper & Servo Motors
    Last Post: 26-11-2012, 12:26 PM
