Another thing to consider is: Did you measure it under load?
A transformer usually specified under full RESISTIVE load. So, when unloaded the voltage increases by the specified regulation figure. I guess you tested it unloaded in which case you are safe. Calculating the output voltage of a transformer/rectifier under mixed capacitive and resistive load is by no means easy. For a one off, your approach of try it and see is the best way.
Russell.
screening / glitchy operation - sanity check
By dsc in forum General ElectronicsReplies: 21Last Post: 01-12-2013, 11:35 PM -
Toroidal Transformer
By Carlb1058 in forum General ElectronicsReplies: 7Last Post: 17-08-2013, 06:54 AM -
maximum deflection - sanity check
By dsc in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 11-02-2013, 09:33 AM -
Different voltages on different steppers
By Lovre in forum Motor Drivers & ControllersReplies: 2Last Post: 12-12-2012, 11:28 PM -
sanity check - constant running, loads and more
By dsc in forum Stepper & Servo MotorsReplies: 4Last Post: 26-11-2012, 12:26 PM
