Thread: Diy Brushless Spindle
11-10-2012 #121
12-10-2012 #122
i think they where sent in may... PM sent
The Following User Says Thank You to blackburn mark For This Useful Post:
12-10-2012 #123
PM replied to Mark.....
I've got 150 off P188207 Belleville Washers coming early next week so think I should have enough for this and any other spindle I might be wanting to do :D
12-10-2012 #124
Question to you guys is how well do the DC motors handle heat when running at different RPM's? Also would setting up a PID type closed loop controller work with a DC motor? Looking at options with one of the other members and a DC brush-less motor is looking like the best option for providing the need power and from the looks of it the needed RPM's as well. Has anyone though of side mounting the motor and connecting it via belts to the spindle (possibly using a key way to help lock the pulleys to their spindles). This would some variance in torque and from what I can see would really make the spindle have a rather wide range of uses.
Just asking as kicking around ideas and designs and these are points that have run across. Anyone happen to know a source for variable speed AC motors in the 1.5kw range that don't cost the moon or come from questionable quality control?
Michael
12-10-2012 #125
I'm not sure if you're referring to the motors discussed in this thread, which are brushless AC motors, or normal DC motors? Either way a PID control algorithm can be used to improve the performance. A DC-servo motor is just the motor with encoder and PID control for position and speed.
14-10-2012 #126Question to you guys is how well do the DC motors handle heat when running at different RPM's?
Where i do have concerns is the ESP (speed controller) they do get hot... iv not blown one yet but i bought a spare because i thought i might with the amount of heat they push out (no problems though so far) at £20 (ish) its silly not to have a spare.
with a 12v 350w power supply the majority of my spindles are vastly under the “claimed” potential and iv not once thought I needed more power/torque… im sure our honorable speed freak friend Jonathan would want more speed n torque (you would need the extra speed if you wish to cut wood…I’m cutting plastic 90% of the time, I don’t cut any wood at all)
if your cutting wood and alli/plastics its worth weighing up if making two spindles is easier than dealing with pulleys on one ?
14-10-2012 #127
Most model ESCs are mounted where there us some airflow (the ones I have in my planes all have air ducts directing air onto them and the one on my Trex 500 heli is on the side so in the downdraught) so I'll be putting a 24V fan by mine for cooling.
Belleville washers arrived today but just back in from a weekend away so will be tomorrow before I complete the spindle now :)
17-10-2012 #128
A fan does make a big difference to the ESC (not ESP!
) temperature - I put fans on the ESC(s) in my model car for the same reason. A lot of model car ESCs include fans now since the airflow tends to be poor in that application.
Bit off topic, but is that a genuine T-rex or did you get a cheap copy? I got the latter, but can't say I've used it much yet as I always seem to have other things to do...
How much did all those springs cost?
17-10-2012 #129
It's a genuine Trex 700 nitro, don't think HK do a copy....yet ;)
The main reason I've not got further with this project is I've probably spent 2.5k on helis in the last 18 months to the exclusion of everything else!
They cost £15 + the dreaded and P&P so I think approx £25 in total...still got about 130 left :)
17-10-2012 #130
There are currently 47 users browsing this thread. (0 members and 47 guests)
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
All-In-One Brushless Servo System
By Gytis in forum Stepper & Servo MotorsReplies: 0Last Post: 22-12-2015, 10:21 PM -
DIY Brushless spindle
By booski in forum Brushless Spindles & MotorsReplies: 2Last Post: 30-10-2013, 09:36 AM -
Using RC Brushless motors as spindle
By Jonathan in forum Brushless Spindles & MotorsReplies: 30Last Post: 20-12-2012, 08:51 PM -
Mach 3 control of DC Brushless motor?
By templecorran in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 18-11-2010, 04:20 PM
