Thread: Diy Brushless Spindle
i bought a pair of those 708A bearings but never got around to implimenting them as i ended up using the larger spindles most of the time and the skate bearings seem to be holding up to the amount of use that they get
the 8mm shaft motors make sense if your cutting balsa because of the higher KV choices
i did mull the idea for a spell as i belive the larger brushless spindles would knock the knickers off a kress or even one of those posh water cooled chinese jobs at cutting ali and plastics (especialy so if your finishing with a fly cutter) but i get the feeling most people are after cutting wood on their cnc routers and stick to small tooling to cut the odd bit of alli so im not sure there would be a demand myselfI maintain there's a tidy little sideliness/embryonic business for someone
yep! its a crying shame you cant get them smaller :cry: they work like a charm and make the job eeeeasy!!!From a quick search on tinternet it seems that most double row angular contact bearings seem to start at 10mm ID
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
All-In-One Brushless Servo System
By Gytis in forum Stepper & Servo MotorsReplies: 0Last Post: 22-12-2015, 10:21 PM -
DIY Brushless spindle
By booski in forum Brushless Spindles & MotorsReplies: 2Last Post: 30-10-2013, 09:36 AM -
Using RC Brushless motors as spindle
By Jonathan in forum Brushless Spindles & MotorsReplies: 30Last Post: 20-12-2012, 08:51 PM -
Mach 3 control of DC Brushless motor?
By templecorran in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 18-11-2010, 04:20 PM
