    Cheers John, when you know what they're called they're everywhere!! Still got to work out how to shield them.......
    Neil...
    Build log...here
    In the smaller sizes they are known as magneto bearings, Arc keeps them, ask for E8's
    Hmm, I even looked there... must be blind:
    http://www.arceurotrade.co.uk/Catalo...-Ball-Bearings
    Aluminium disk or whatever with only a very very small clearence - enough to stop it touching, but not so big that it lets lots of dust in. I believe the term is aluminium labyrinth. Any seal which touches is going to generate a lot of heat due to friction.
    Or...
    http://simplybearings.co.uk/shop/p42...duct_info.html
    or...
    http://www.ebay.co.uk/itm/E8-MAGNETO...item2eaeaac383
    etc.....etc...
    Was going to see if I could reverse engineer a shield like on the 608RS bearings....or how about http://simplybearings.co.uk/shop/p24...duct_info.html but not sure what speed it's rated to....food for thought anyway!
    Neil...
    Build log...here
    Yes, easy once you know...
    I doubt rubber seals are appropriate for the speed this will be running at. The bearings apparently already get hot, so a seal like that is just going to make it worse. I used some on my wind turbine, for each blade, and they add a lot of friction...but it didn't matter there as it's only a few rpm.
  1. Replies: 4
  2. All-In-One Brushless Servo System
    By Gytis in forum Stepper & Servo Motors
    Last Post: 22-12-2015, 10:21 PM
  3. DIY Brushless spindle
    By booski in forum Brushless Spindles & Motors
    Last Post: 30-10-2013, 09:36 AM
  4. Using RC Brushless motors as spindle
    By Jonathan in forum Brushless Spindles & Motors
    Last Post: 20-12-2012, 08:51 PM
  5. Mach 3 control of DC Brushless motor?
    By templecorran in forum Artsoft Mach (3 & 4)
    Last Post: 18-11-2010, 04:20 PM
