Thread: Diy Brushless Spindle
I'll have to wait until I get the motor for the through mounting hole dimensions but was thinking of something along these lines.....
31-10-2011 #2eeeerrrr, dunno?? pretty sure i got them on ebay.... i just did a search and they are all coming up USA which is a bit of a bind, iv got some left (8.2mm inside 18.9mm outside diameter) so measure the distance your going to have between your bearings ill send you enough to fit that gap (n youll owe me a favourMark, where did you get your belleville washers from? Was going to stick a couple in between my single row AC bearings?
... its not the washers, its the dragging my arse over to the post office that youll owe me for
iv used 12 washers and compressing them about 0.5mm (very light, less than 1kg) i guess you could be a little more aggressive with those A/C bearings but im not sure to what advantage ?? id play it safe and keep it light... if you get any signs of movement slop chatter add a shim etc.
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
All-In-One Brushless Servo System
By Gytis in forum Stepper & Servo MotorsReplies: 0Last Post: 22-12-2015, 10:21 PM -
DIY Brushless spindle
By booski in forum Brushless Spindles & MotorsReplies: 2Last Post: 30-10-2013, 09:36 AM -
Using RC Brushless motors as spindle
By Jonathan in forum Brushless Spindles & MotorsReplies: 30Last Post: 20-12-2012, 08:51 PM -
Mach 3 control of DC Brushless motor?
By templecorran in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 18-11-2010, 04:20 PM
