Neil,
Looks like it's coming along!
I've had a shake up here as well, lots of my toys are still in boxes. Was laid off, found a job, moved from California to Michigan (~2300 miles!), bought a house... phew, that makes me tired all over again thinking about it!
Here are some pics of my copycat spindle design, I think I'm in the same spot of the build as you are Neil.
Name:	8mm Spindle Assembly - Outrunner Version - IMG 1.JPG
ID:	6032Click image for larger version.
Name:	8mm Spindle Assembly - Outrunner Version - IMG 2.JPG
ID:	6033Click image for larger version.
Name:	8mm Spindle Assembly - Outrunner Version - IMG 3.JPG
ID:	6034Click image for larger version.
Name:	8mm Spindle Assembly - Outrunner Version - IMG 4.JPG
Name:	Z-Axis Assembly - Tight - IMG 1.JPG
I'm using a Turnigy G110 motor, two 8x22x7 angular contact bearings, 4 belleville washers, and an er11 collet with 8mm shank. I'm mostly going to use this spindle for light work: plastics, engraving, PCB cutting, etc.
I'm a little concerned the bearings will heat up, any thoughts on this?
Also, did you re-install the e-clip ring onto the new shaft?
