    i personaly wouldnt get to bogged down in all the rocket science... make sure you get some tension in your balls and make sure your shaft cant easily rotate in the bearing bore (loctight the nose bearing if its a tad slack) and all should be fine
    any slack will result in balls skidding or a sypathetic rolling rotation/vibration between your shaft and your bearing bores
    (a very short life span for either and poor finishes)
    iv used super cheap skate bearing on my er11 with aprox 2kg of tension between the two and its still going strong
    if you get any high pitched squeals/squeaks etc when the spindle runs up or down you need to fettle
    the beauty of these spindle is they are cheap n simple
    iv seen threads on diy spindles that are works of art and that have followed the theory to the letter, however, i get good finishes in acetal and alli so seen no point in getting all posh if the aim of the game is to get yourself up and cutting :)
    PS: your bellville washers are bagged n ready neil, i just need to get off my arse and post them :(
  2. The Following User Says Thank You to blackburn mark For This Useful Post:
  3. #2
    Cheers Mark, no huge rush as I've still got lots to do on the router (everything apart from the base!!) which I'm hoping to break the back of over the weekend.
    Neil...
    Build log...here
  1. Replies: 4
  2. All-In-One Brushless Servo System
    By Gytis in forum Stepper & Servo Motors
    Last Post: 22-12-2015, 10:21 PM
  3. DIY Brushless spindle
    By booski in forum Brushless Spindles & Motors
    Last Post: 30-10-2013, 09:36 AM
  4. Using RC Brushless motors as spindle
    By Jonathan in forum Brushless Spindles & Motors
    Last Post: 20-12-2012, 08:51 PM
  5. Mach 3 control of DC Brushless motor?
    By templecorran in forum Artsoft Mach (3 & 4)
    Last Post: 18-11-2010, 04:20 PM
