Thread: Diy Brushless Spindle
19-06-2012 #11
The motor linked to above is rated to 70A which should match OK with the 100A SC. In theory this would give 1920watts (24v x 70A) which sounds enough to machine wood. The actual amps pulled (for a given motor) will depend on the cutting load, but I'm not sure how easy this is to calculate. If you pull too many amps during the cut the SC will probably pop.
For this reason myself and other model aircraft users often use an ammeter to check the current draw on the ground for a given prop to make sure all is well before the first flight. If the SC gives up in the air, since it sometime also powers the reciever you loose the plane.
You could do the same thing for the first cuts to check your safety margin.
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
All-In-One Brushless Servo System
By Gytis in forum Stepper & Servo MotorsReplies: 0Last Post: 22-12-2015, 10:21 PM -
DIY Brushless spindle
By booski in forum Brushless Spindles & MotorsReplies: 2Last Post: 30-10-2013, 09:36 AM -
Using RC Brushless motors as spindle
By Jonathan in forum Brushless Spindles & MotorsReplies: 30Last Post: 20-12-2012, 08:51 PM -
Mach 3 control of DC Brushless motor?
By templecorran in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 18-11-2010, 04:20 PM
