Thread: Diy Brushless Spindle
03-03-2013 #25
I think you where right in you description of "back to back" sorry :(
you are pushing the inner races apart
as long as the bearing closest to the tool end is tight on the shaft and in the housing I'm guessing all will be well
....now I think about it the inner races shaft and spring washers will all rotate which may be a good reason to go "face to face" because if the washers aren't perfectly central they will cause resonance at high revs
"face to face" would mean the washers don't spin with the shaft as they push against the outer races
that's why I remember "pulling the shaft" so to speak
with the springs between the outer races you need to grip the shaft to hold the tension... in my case I simply used the out runner bell to grip the shaft and hold the tension (not good for your outrunner bearings) what I should have done is add a collar with grub screws, I did have one but I hadn't accounted for the extra room it would take inside the bearing housing
if you don't get what I mean let me know and the next time I'm at home ill take some pictures of mine or knock up a drawing
in a nutshell, instead of pushing the inner races apart from the inside you are pushing them together from the outside
you may suss a better way of doing it ?
let us know how you get on
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
All-In-One Brushless Servo System
By Gytis in forum Stepper & Servo MotorsReplies: 0Last Post: 22-12-2015, 10:21 PM -
DIY Brushless spindle
By booski in forum Brushless Spindles & MotorsReplies: 2Last Post: 30-10-2013, 09:36 AM -
Using RC Brushless motors as spindle
By Jonathan in forum Brushless Spindles & MotorsReplies: 30Last Post: 20-12-2012, 08:51 PM -
Mach 3 control of DC Brushless motor?
By templecorran in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 18-11-2010, 04:20 PM
