Thread: Diy Brushless Spindle
04-03-2017 #29
Just got done with my DIY Brushless spindle. I had everything but the ER16 stub laying around. I'm using an old 320 kV motor and a VESC speed controller (skateboarding). First tests have been very promising, compared to the Colt trim router I'd been using.
The VESC will hold the RPM very close under varying loads. I've only tested it on 6S batteries, but my CNC runs on 42V so that should be close to getting it to speed.
I cast the adapter tube in Urethane (again, stuff laying around). A lot of work, but not bad for only needing to spend $20.
The VESC BLCD software will show volts, amps, etc. live if it's hooked up via USB. I always thought it would be a neat idea to slow the feed rates down based on load. I'm running LinuxCNC but have no idea how I'd hook all that up.
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
All-In-One Brushless Servo System
By Gytis in forum Stepper & Servo MotorsReplies: 0Last Post: 22-12-2015, 10:21 PM -
By booski in forum Brushless Spindles & MotorsReplies: 2Last Post: 30-10-2013, 09:36 AM -
Using RC Brushless motors as spindle
By Jonathan in forum Brushless Spindles & MotorsReplies: 30Last Post: 20-12-2012, 08:51 PM -
Mach 3 control of DC Brushless motor?
By templecorran in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 18-11-2010, 04:20 PM
