Thread: router jumping position
i was cutting a sample 3d part today just trying things out, roughed it out fine, changed tool and then started finishing. after a few cuts router basically lost position but the motors did not stall, it was as if it missed a couple of lines and then moved on. not sure what happened. anyone got any ideas
22-09-2011 #2
Trying to go too fast ?
What do you have acceleration and velocity set to ?
Also who breakout board are you using ?John S -
22-09-2011 #3
feed in the program was 1500mm/min
22-09-2011 #4
its a routout cnc breakout board. velocity set to 2000mm/min max. accellleration is set to about 0.25 seconds. the rest of the progrm ran fine it was just this one bit that did it so i don 't think the velocity/acceleration is a problem hopefully
22-09-2011 #5
Velocity and feed sound reasonable but acceleration sounds very high, might not be able to have time to move, try increasing the time.
John S -
22-09-2011 #6
One way to see if it's going to stall is run something like this:
G61
G0 X0 Y0
G0 X100 Y100
G0 X0 Y0
G0 X100 Y100
G0 X0 Y0
G0 X100 Y100
G0 X0 Y0
G0 X100 Y100
etc...
Doing that clearly moves X and Y at maximum feed, then reverses ... so if the acceleration is wrong that's quite likely to stall it. My machine used to stall if I ran that code at 8m/min, then I changed the computer to a better one and it'll do that at 15m/min without stalling.
22-09-2011 #7
Best to put a G21 on the top line in case he's from the States :lol:
John S -
23-09-2011 #8
23-09-2011 #9
LOL !!
John S -
23-09-2011 #10
npe i'm from uk, cornwall and i do have limits so it won't matter any way. i'll try turning the accelleration down a little.thanks
Spindle position sensor
By GeoffV in forum Motor Drivers & ControllersReplies: 3Last Post: 23-03-2014, 10:00 PM -
Machine tool transporters that will move machines into position
By komatias in forum Marketplace DiscussionReplies: 6Last Post: 09-08-2013, 07:27 AM -
Mach3 Tool Change Position
By Mad Professor in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 15-07-2013, 06:54 PM -
Position feedback
By D.C. in forum Electronic Project BuildingReplies: 4Last Post: 17-10-2012, 11:30 AM -
Manual Miller Position, Bracknell
By GMNOCNC in forum Opportunities Available & SoughtReplies: 0Last Post: 23-03-2011, 07:46 PM
