Thread: Mounts; Motors, bearings etc..
29-09-2011 #17
Yep, that's the plan... get all the hardware, check it against the estimates I've been using and then tweak the metal work to suit in the design and then order the metal and start the build...
Pre machined.I’m not sure if you’re buying pre machined ball screws or turning them down yourself,
The design is going with me to the shops so I should be able to see if anything is going to cause me any problems before I part with any cash. I'm sure there will still be some surprises.
:naughty:
taper roller bearings vs deep groove ball bearings
By dsc in forum Linear & Rotary MotionReplies: 8Last Post: 10-03-2014, 08:06 AM -
RFQ: Ballnut Mounts needed.
By dudz in forum Projects, Jobs & RequestsReplies: 1Last Post: 05-03-2014, 09:01 AM -
New spindle needing new mounts
By Cncparts in forum Machine DiscussionReplies: 17Last Post: 04-12-2013, 11:14 PM -
RFQ: Nema 23 motor mounts
By luke11cnc in forum Projects, Jobs & RequestsReplies: 14Last Post: 06-10-2011, 02:21 PM -
DIY Nema23 Motor Mounts
By Lee Roberts in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-08-2009, 06:08 PM
