Thread: Steel Framed CNC router
02-07-2012 #11
Ermmm without seeing design or intended components it's hard to say but £1500 would be a more realistic figure but with some carefull buying/scrounging/stealing.
for a steel frame based machine using supported round rail and chinese ballscrews then it's just about do-able but you'll have absolutely no room for error in the design.!!
Yes thats exactly the same type of spindle I use and recommend. For the money they simply can't be beat.
They eat aluminium for breakfast and will happly cut it for days none stop with just a simple cooling setup(sub Pump in 25ltr drum), I've had mine cut non stop for 34hrs and still only be mildly above warm and no where near hot.
They are very quite compared to a router and power wise they blind even the highest powered routers which can't really hold a candle to them. They are flexible regards tool size with collets from 1mm to 13mm with far superior runout to routers. If you look on the forum you'll see pics of the aztec calender I cut and here is a vid showing the detail and thats just using a 90deg spot drill.!! . . . Far finer detail is possible with proper engraving bits.!!. . http://www.youtube.com/watch?v=wjDvimSdH8M&feature=plcp
They do have a one draw back and that is the minimum 5000rpm speed, go below this and the torque drops away very quick and not really usable so they don't lend them selfs to drilling using large drill bits.!! . . . I get round this by simply pocketing large holes.!
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
BUILD LOG: Formed steel cnc router
By sbams in forum DIY Router Build LogsReplies: 4Last Post: 07-03-2013, 02:00 AM -
BUILD LOG: Steel Framed Router
By GTJim in forum DIY Router Build LogsReplies: 52Last Post: 14-09-2011, 06:51 PM -
BUILD LOG: My steel framed router
By pavlo in forum DIY Router Build LogsReplies: 17Last Post: 06-03-2011, 10:08 PM
