Same/very similar problem here. When jogging an X-Y table with MACH3 at full speed (400mm/min) in either the Y+/Y- direction and then, at the same time, attempting to jog either X+/X- at full speed [and completely vice versa] there are a lot of loud horrible mechanical noises and the table clearly stops moving correctly. This is 100% repeatable. Not seen this happen when machining a piece - that said I'm not aware of a situation where the machine is asked to move full speed in, say, the X direction whilst it's already moving full speed in the Y direction. I assumed - for no good reason - that this was a MACH3 jogging thing. So now I'm very interested in the answer.
Setup:
Motors: SY60STH88-3008BF (x3)
Driver: PM542 @ 1,600 pulses per rev, 2.37A(Peak) [1.69A(RMS)]
Supply: 43V
MACH3 motor config': 627 steps per mm, 400mm per min
05-10-2011 #2
Nothing to stop you running a program like this. It's conceivable on a drilling cycle.
G21 G61
G0 X0 Y0
G0 X100 Y100
G0 X0 Y0
G0 X100 Y100
G0 X0 Y0
G0 X100 Y100
You and Steve are both running these motors in Bipolar series, not parallel ... interesting.
05-10-2011 #3
Hi Jonathan..
I had always thought bipolar series was preferred to get the higher speeds? Is parallel better?
Steve..
05-10-2011 #4
Yes parallel is generally faster. Bear in mind the current the drivers is set to also makes a difference as the torque is roughly proportional to the current (until you go much above the rated current and the rotor saturates). If the nearest current setting to the current in series is greater than the parallel setting then it may not make much difference. Karl has the motors on 2.37A, and the rating is 2.1A so it's already 13% over. The PM542 maximum is 4.2A, so the same as the motors ... so if putting in parallel gains less than 13% then you may not gain anything though it would be nicer. There's more to it than that though... in the end it's easiest to just try it and see. Keep an eye on the motor temperature too.
05-10-2011 #5
05-10-2011 #6
However, for completeness, the torque when wired in bipolar series is greater at low speed than the same motor wired in parallel.
It looks like in Steve's case it's the Y/Z axis motors that are in series, and they're not at fault. Still worth trying, as long as the power supply can take it.
05-10-2011 #7
Yep exactly, thou as the speed rises the torque drops away very quick in series and because the X axis needs the most torque due to it's mass and it's happening when rapiding I'd be changing to parallel.
Edit: That said I still don't think this is Steves problem due to him having the problem at lower speeds.?????
05-10-2011 #8
Just taken some motor current measurements on my machine - measured at the output of the star-wired PSU:
- Powered up but stationary the 3 drivers and motors together pull 0.87A (DC) total. Motors bipolar series. Driver PM542 settings now 2A (RMS) limited.
- MACH3 jogging X,Y or Z axis individually pulls 1.36A during acceleration levelling at 1.25A - this is the machine's full MACH3 limited speed of 400mm/min.
Jogging in, say, X and then also jogging Y - ie causing the horrible mechanical noises and poor movement - pulls 1.6A to 1.9A total.
Jogging the Z full speed and then - at the same time - jogging either the X or Y in any direction does not cause any problem (likewise moving either X or Y and then engaging Z causes no problem).
My PSU is rated at (43V) 5+ amps so, given the figures above, current does not seemed to be an issue.
I'm wondering if this problem is due to inertia/momentum/twisting forces in the, not very expensive, X-Y table?
Digital Drivers and Stall Detection
By Washout in forum Motor Drivers & ControllersReplies: 6Last Post: 10-12-2013, 05:02 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
