Are your phase cables and signal cables shielded?
If not you may find that noise is being picked up on the signals.
This may be hitting the direction signals and causing one of the x axis to be changing direction?
disconnect the direction signals on the x axis and see if it still happens.Visit Us: www.automationshop.co.uk
04-10-2011 #2
Chicken or egg?
Not sure if the problem caused this, or if this is the problem... On the power supply for the nema 34's (x axis), I have just discovered a 'crispy' component.. Think its a resistor, I can only read '8K' on its blackened surface.. I was about to check voltage outputs from this PSU when I saw a tiny wisp of smoke come from it.. I have switched it all off and will contact the chap that sold it to me to see if he knows what it is..
Steve..
04-10-2011 #3
Ahh must be a switching power supply, good luck getting that fixed. If something has gone wrong with the regulation circuit that would explain your problem.
I forgot to mention in my previous post that the stalling only occurred with mine at or near full speed, and completely went if I made X really slow (it was always X that stalled). This doesn't seem to be the case with yours... so I'm not sure. Maybe try wiring both X drivers to the same step/direction pins on the parallel port and disable the slaving as that should reduce the 'load' on the parallel port.
Also remember that the average current drawn by the stepper motor is not a simple function of speed...
04-10-2011 #4
Hi Jonathan..
Just emailed you again;
Just had a real close look at it with a loupe, I can see a single strand of wire from the +ve very close to the –ve.. Reckon it may have been arcing.. Tried to take a pic for you but my camera/phone cant take pictures that close and all I could get is a blur..
Part of me is relieved as this could well be the source of my probs... You set the the PSU for two outputs, 65v 8amps which I am pretty sure is fine for those motors.. Yes please, if you can send me a replacement rectifier, I will solder it on.. The -ve wire is also crispy so will replace that too...
Steve..
04-10-2011 #5
Ok, I've got a few 35 amp ones lying around which should do the trick.
I'm a bit worried now you appear to be using this power supply with the PM542 drivers? I thought is was PM752. If that's the case it's bad as those drivers are only rated for 50V. I'll check in our emails what voltage the transformer actually is/was.
EDIT: Nevermind, that's me being an idiot...it's the PM752 so not a problem.
I really need to go now.
Digital Drivers and Stall Detection
By Washout in forum Motor Drivers & ControllersReplies: 6Last Post: 10-12-2013, 05:02 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
