04-10-2011 #9
Ahh must be a switching power supply, good luck getting that fixed. If something has gone wrong with the regulation circuit that would explain your problem.
I forgot to mention in my previous post that the stalling only occurred with mine at or near full speed, and completely went if I made X really slow (it was always X that stalled). This doesn't seem to be the case with yours... so I'm not sure. Maybe try wiring both X drivers to the same step/direction pins on the parallel port and disable the slaving as that should reduce the 'load' on the parallel port.
Also remember that the average current drawn by the stepper motor is not a simple function of speed...
Digital Drivers and Stall Detection
By Washout in forum Motor Drivers & ControllersReplies: 6Last Post: 10-12-2013, 05:02 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
