05-10-2011 #11
Same/very similar problem here. When jogging an X-Y table with MACH3 at full speed (400mm/min) in either the Y+/Y- direction and then, at the same time, attempting to jog either X+/X- at full speed [and completely vice versa] there are a lot of loud horrible mechanical noises and the table clearly stops moving correctly. This is 100% repeatable. Not seen this happen when machining a piece - that said I'm not aware of a situation where the machine is asked to move full speed in, say, the X direction whilst it's already moving full speed in the Y direction. I assumed - for no good reason - that this was a MACH3 jogging thing. So now I'm very interested in the answer.
Setup:
Motors: SY60STH88-3008BF (x3)
Driver: PM542 @ 1,600 pulses per rev, 2.37A(Peak) [1.69A(RMS)]
Supply: 43V
MACH3 motor config': 627 steps per mm, 400mm per min
Digital Drivers and Stall Detection
By Washout in forum Motor Drivers & ControllersReplies: 6Last Post: 10-12-2013, 05:02 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
