However, for completeness, the torque when wired in bipolar series is greater at low speed than the same motor wired in parallel.
It looks like in Steve's case it's the Y/Z axis motors that are in series, and they're not at fault. Still worth trying, as long as the power supply can take it.
05-10-2011 #2
Yep exactly, thou as the speed rises the torque drops away very quick in series and because the X axis needs the most torque due to it's mass and it's happening when rapiding I'd be changing to parallel.
Edit: That said I still don't think this is Steves problem due to him having the problem at lower speeds.?????
05-10-2011 #3
Just taken some motor current measurements on my machine - measured at the output of the star-wired PSU:
- Powered up but stationary the 3 drivers and motors together pull 0.87A (DC) total. Motors bipolar series. Driver PM542 settings now 2A (RMS) limited.
- MACH3 jogging X,Y or Z axis individually pulls 1.36A during acceleration levelling at 1.25A - this is the machine's full MACH3 limited speed of 400mm/min.
Jogging in, say, X and then also jogging Y - ie causing the horrible mechanical noises and poor movement - pulls 1.6A to 1.9A total.
Jogging the Z full speed and then - at the same time - jogging either the X or Y in any direction does not cause any problem (likewise moving either X or Y and then engaging Z causes no problem).
My PSU is rated at (43V) 5+ amps so, given the figures above, current does not seemed to be an issue.
I'm wondering if this problem is due to inertia/momentum/twisting forces in the, not very expensive, X-Y table?
Digital Drivers and Stall Detection
By Washout in forum Motor Drivers & ControllersReplies: 6Last Post: 10-12-2013, 05:02 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
