Still happens with the ballnuts disconnected, I had removed the ballnuts last week and cleaned them out, then tested that principle as I was originally thinking along the same lines.. The problem can happen at any position on the bed (2mt x 1.4mt) although it seems to happen much more on moving the x axis +, rather than -..
Mechanically, the machine is sound and I have torn apart and rebuilt it twice in the last week, everything is freely moving..
If I get a chance, I will make a little video of it happening later today..
Steve..
06-10-2011 #2
at what RPM on the motors does it stall? is it at the same speed all the time? Do both motors on the X stall even if they are not linked mechanically?
Visit Us: www.automationshop.co.uk
06-10-2011 #3
It is stalling at all speeds.. Had it as low as 500mm/min up to 2500mm/min.. Acceleration from 10 - 120.. Stalls at any speed.. The x axis is completely unaffected by the z axis.. It only happens when the Y and x is both moving at full speed..
Digital Drivers and Stall Detection
By Washout in forum Motor Drivers & ControllersReplies: 6Last Post: 10-12-2013, 05:02 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
