Ok...
Seems my run of bad luck is continuing..! Got an EP002G1 psu from a fellow forum member, but I have measured 58.8v output unregulated..! I know this is much higher than it should be (42-46v on the spec sheet).
This is too much for the drivers I am using which are limited at 50v (already blown one of them).. I know there are many out there that have these psu's and am wondering if there is anything I can do to 'dial' down the voltage? Will pop the cover off a bit later and see if there are any pots but this is like letting a road digger perform brain surgery and I would prefer some advice before rummaging around in it..
Steve..
Digital Drivers and Stall Detection
By Washout in forum Motor Drivers & ControllersReplies: 6Last Post: 10-12-2013, 05:02 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
