Quote Originally Posted by fasteddy View Post
Chicken or egg?
Not sure if the problem caused this, or if this is the problem... On the power supply for the nema 34's (x axis), I have just discovered a 'crispy' component.. Think its a resistor, I can only read '8K' on its blackened surface.. I was about to check voltage outputs from this PSU when I saw a tiny wisp of smoke come from it.. I have switched it all off and will contact the chap that sold it to me to see if he knows what it is..
Steve..
Ahh must be a switching power supply, good luck getting that fixed. If something has gone wrong with the regulation circuit that would explain your problem.
I forgot to mention in my previous post that the stalling only occurred with mine at or near full speed, and completely went if I made X really slow (it was always X that stalled). This doesn't seem to be the case with yours... so I'm not sure. Maybe try wiring both X drivers to the same step/direction pins on the parallel port and disable the slaving as that should reduce the 'load' on the parallel port.
Also remember that the average current drawn by the stepper motor is not a simple function of speed...
