Sorry Jonathan should made it clearer.!..I was refering to a telephone conversasion I had with Steve.
Seriously don't get your fasination with speed jonathan.?. . . The ONLY thing it's usefull for is Rapids and seen as 85% + of the time a machine spends is cutting why go to all the trouble of rotating nut, esp on a machine with twin screws .? . . . I see the bennifit of rotating nut to allow long screws but not extra speed and 10mtr/min rapids is good enough for most machines even an 8 x 4.!
Let me ask you this.? What do you CUT above 10mtr/min.?? . . .Not much if anything I bet.! . . Also out of the last job (other than mass drilling, which high rapids can help) you cut how much of the overall job cycle time consisted time wise of rapid moves.? . . bet it was easily less than 10% of total cycle time.?
Thats an awfull lot of extra work and expense incorparating 2 rotating ballnuts into a DIY machine just to gain a few percent saving on cycle times, the Key word being DIY machine where cycle times are usually not an issue. . . .Yes in industry every little bit helps but in DIY it's not worth the expense and trouble just for a few percent.!! . . IF . . normal screw setup can be used.
Said this before .!!. . .It takes a substancial machine with a powerfull spindle using high quality tooling to cut at high feed rates. . . . High rapids are only usefull on very small percentage of jobs other than that they are just used for bragging.!!
Also seen as most DIY builders use modified routers usually of the cheaper quality range or spindles like Kress then high cutting feeds with any reasonable depth are simply not achievable anyway.
Digital Drivers and Stall Detection
By Washout in forum Motor Drivers & ControllersReplies: 6Last Post: 10-12-2013, 05:02 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
