Quote Originally Posted by fasteddy View Post
Just a thought...
Have been roving around all the cnc forums trying to find another with the same probs... I have seen an awful lot of posts about earthing, but I have to say, as a complete burp at electronics, I ended up more confused than when I started... Cant get my head aound the myriad of different advice being handed out, and much of it was american.. Do they use different terms for all that common,starpoint,earth,neutral,-ve supply/rail,0 volt stuff? Damned if I can work out what they are in English without even more varying terminology.. I ramble..
Does seem to be a big cure-all for a lot of electronics issues so I was wandering if there is a good post/guide to earthing for us feeble minded noobs? From what I have read, I ought to do this as a matter of course, if only to eliminate several potential problems...
Steve..
Hi Mate, are you using Mach3 with a parallel port? If so what kernel speed are you using and what is the maximum velocity for the X and Y axis.
Mike.
