Thread: What mill bits?
These:
http://www.ebay.co.uk/itm/5x-6mm-Car...ht_2687wt_1037
I use them a lot... I've done anything up to 25mm thick with them.
Yep, the bits don't squash that much :lol:
If you're cutting all the way through this 10mm aluminium then get the 6mm cutter as it's a huge amount more rigid than 1/8" and there's more space for the swarf to clear. That means you can cut faster (higher depth of cut and feedrate), and I guess the cutter will last longer too. I use mine on the router at 1.2mm depth of cut and 600mm/min @ 11000rpm, just putting coolant on with a pipette (so much easier than a brush) every so often. If you're using a rigid milling machine they will cut through 10mm in one pass, but on a router you need to use less as framework and spindle are not as strong.
A 1/8" wide slot 10mm deep is needlessly annoying if you can fit the 6mm cutter in.
The Following User Says Thank You to Jonathan For This Useful Post:
3d carving bits
By drut in forum Tool & Tooling TechnologyReplies: 9Last Post: 04-07-2013, 01:03 AM -
FOR SALE: Bits for Sale
By petesurrey in forum Items For SaleReplies: 2Last Post: 27-10-2011, 06:55 PM -
RFQ: need someone to cnc/mill some bits for me
By neurofen in forum Projects, Jobs & RequestsReplies: 0Last Post: 04-02-2011, 10:13 AM -
best drill bits
By oadamo in forum Tool & Tooling TechnologyReplies: 4Last Post: 01-01-2011, 11:25 PM -
CNC Router Bits
By ploughex in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 01-08-2010, 06:26 PM
