Thread: Tooling
10-10-2011 #1
So where does everybody buy their endmills and engraving bits from then?
Ian
10-10-2011 #2
china through ebay mostly
if you buy any of the single flute carbide cutters from china make sure you measure them.... they tend to work great but can come in slightly under size
10-10-2011 #3
The single flute cutters are good. I didnt think they would be but I got some a few weeks ago and I like them alot.
Ian
10-10-2011 #4
and as jonathan pointed out, with single flutes you can re-sharpen them pretty easy if you chip the tip
10-10-2011 #5
eBay or toolstation for cheaps.
Single flute cutters seems generally amazing on router... I've been using 6mm and they're good with aluminium/nylon/polycarbonate/plywood but I've almost exclusively used them on aluminium as I've not been cutting much else.
Still this is irrelevant if it turns out you're using a milling machine and cutting steel! What are you intending to cut?
11-10-2011 #6
I'll be cutting mostly alumium. Can you point me in the direction of the single flute cutters to which you refer.
There was a recent thread on this - do a search for 'single flute' on this forum (I don't know how to post a thread link).
11-10-2011 #8
http://www.ebay.co.uk/itm/10-x-1-8-C...item20b95dbb56
http://www.ebay.co.uk/itm/5x-6mm-Car...item20b95dbb6d
the 3.175mm tend to be closer to 3mm so make sure you get your micrometer on them just to check.... i do somtimes cut alli with a bit of WD40 for lube but work mostly in acetal with a tiny bit of air (large fish tank type pump
) to keep any slots from filling with chips and glogging
they last a long time in acetal, i snap more of them than i wear out
11-10-2011 #9
Mark has linked to the ones I bought.
This is it:
http://www.mycncuk.com/forums/showth...rbide-cutters/
11-10-2011 #10
Thanks gents.
My main intention is to cut thin sheet aluminium. Success to date has been mixed. I think I've been using soft alu, so I've been suffering with the plate not cutting cleanly.
I've ordered some of the recommended cutters and some "harder" aluminium sheet so I'll hopefully have more success.
Ian
FOR SALE: tooling for sale
By davy in forum Items For SaleReplies: 4Last Post: 10-11-2012, 11:37 PM -
Tooling Up advice
By Mad Professor in forum Tool & Tooling TechnologyReplies: 4Last Post: 22-08-2012, 02:29 PM -
HSK Tooling
By Dairsie in forum Tool & Tooling TechnologyReplies: 3Last Post: 02-09-2011, 10:07 PM -
BT 35 tooling and DA holders
By Kai in forum General DiscussionReplies: 0Last Post: 19-07-2011, 03:22 PM -
UK Tooling Supplier
By audioandy in forum General DiscussionReplies: 1Last Post: 13-07-2010, 03:25 PM
